Oil quantity
Oil quantity
Just changed the engine oil on my 200tdi plus the filter. The haynes book of lies says it needs 6.85 litres for this. I only put 4 and a bit in and it's up to the level, even after running the engine to fill the filter.
Is the haynes wrong?
Just checked again and it's just over the high mark. The dipstick is buried under the turbo hose, so much so that you have to distort the hose to get it past. Is that usual? or has someone fitted a different dipstick tube in the past?
The oil I drained out was only about 4-5 litres too and had been on the N mark on the stick. I've never had the oil pressure light come on while running and it goes out seconds after starting.
The following is taken from the Landrover 200Tdi Defender supplement
CAPACITIES
The following capacity figures are approximate and are provided as a guide only. All oil levels must be set
using the dipstick or level plugs as applicable.
Engine sump oil ................................................................ 6,OO litres (10.56 pints)
Transfer box oil ................................................................ 2,30 litres (4 pints)
Cooling system ................................................................ 11,10 litres (20 pints)
Extra when filling following new filter .............................. 0,85 litres (1.50 pints)
CAPACITIES
Well, checking around on other forums and Bo's response had confirmed that I hadn't got enough oil in there but the stick was showing full.
The dipstick length is 465mm from tip to the bottom of the bell shaped cover.
The tube is 225mm from the top of the nut on the engine to the top of the tube. Then I wiggled it a bit and suddenly got an extra 30mm
One of the forums gave a length for the tube as 295mm so I need to investigate further. I've added another litre to get it to the N mark now so thats maybe 6 in total.
Can anyone with a 200tdi 90, measure the length of the dipstick tube from the top of the nut on the engine to the top of the tube please?
Users browsing this forum: No registered users and 59 guests
