What size are my nuts
Postby tecnick » Wed Oct 13, 2010 7:12 pm
Going to start the re-bushing of the 90 at the weekend. Does any one know what size spanner I need for the radius and trailing arms.
Postby Matthews » Wed Oct 13, 2010 8:23 pm
You won't be trialling on Sunday then , 17,22,24,29mm should cover it I think.
Postby tecnick » Thu Oct 14, 2010 7:05 pm
Thanks, I hope to trial, we will just do what we can get done in a day.
Hope you make it
Postby Zedman » Thu Oct 14, 2010 7:57 pm
Hope you make it, you would be missed and a whole month to the next event )
Postby davew » Thu Oct 14, 2010 8:07 pm
If I were you Nick I'd try slackening and moving the four front and two rear radius arm nuts/bolts to make sure they look like they're free of the centres. If not then you'll end up having to cut them out and it's a LOT simpler to have the replacement nuts and bolts bought before you start the job proper !
Postby varleym » Fri Oct 15, 2010 9:58 am
Would agree with Dave on this. When I stripped my motor down, although I could get the nuts undone I couldn't get the bolts out as they were stuck fast in the bushes - even with copious amounts of LR tool No 1. I had to grind/hacksaw the bolts to remove the trailing/radius arms from the axles with the rest of the bolt still in the bush. Took them to a local engineering firm to press the old bushes out and the new (Superpro) ones in.
Just a point on the Superpro bushes, the trailing arm bushes are the only split/two piece ones, the rest are one piece. I managed to fit the bushes in everything but the front radius arms (A-Frame, panhard rod, etc) myself just using a vice but as the radius arms are so numb and heavy you either need someone to help you or ideally take it to someone with a hydraulic press.
Postby davew » Fri Oct 15, 2010 10:03 am
You can put the SuperPro (or any of the poly bushes) in very easily using a length of threaded bar, two big washers or pieces of plate and a couple of nuts.
Postby varleym » Fri Oct 15, 2010 10:26 am
I feel like a young Luke Skywalker learning from Obi Wan White :lol: :lol: :lol:
Postby Jabba » Fri Oct 15, 2010 10:33 am
davew wrote:You can put the SuperPro (or any of the poly bushes) in very easily using a length of threaded bar, two big washers or pieces of plate and a couple of nuts.
That's one nut to hold the radius arm and one to hit it with a big hammer :lol: :lol:
Postby davew » Fri Oct 15, 2010 10:35 am
:lol: :lol: :lol:
madcalc
Full Name: david medd
Postby madcalc » Fri Oct 15, 2010 7:52 pm
Did it on the Disco and had no problems. My nuts were really greasy and only used the grinder twice :wink:
Postby Bo » Fri Oct 15, 2010 8:37 pm
RE: "How big are my nuts"
Answer: Not as big as after you have undone the large radius arm fixings.
Postby tecnick » Sat Oct 16, 2010 7:38 am
I'm liking this thread, who would have thought the title would evoke such a response.
Dave, thanks for advice but its now saturday morning and I'm just putting my overalls on :x
Keep those nuts greasy boys :!: :!:
