Defender rear tailpipe section
Postby Jabba » Tue Feb 10, 2015 6:27 pm
The exhaust on my 90 has just the rear silencer box and the pipe that leads out of it to the wing has just fallen off. Does anyone know if I have to have a silencer in the system at all or can I just replace the rear box with a straight through pipe? If so, any ideas where I can get one?
Cheers.
mike
Full Name: Mike Burgess
Re: Defender rear tailpipe section
Postby mike » Tue Feb 10, 2015 9:24 pm
Dominic at Madisons will do you a nice stainless steel one... :D
Mike
Postby Matthews » Tue Feb 10, 2015 9:33 pm
You don't need one as long as it's not too loud and with the turbo it won't be , piece of straight pipe and a couple of bends is the cheapest or a custom exhaust place , mine cost £40 in SS and runs from just in front of the axle over the axle turns 90 deg then up and another 90deg out of wing .
Guy I use in Wortley but can't remember his name atm
Postby davew » Tue Feb 10, 2015 10:48 pm
If you want to make one up yourself, I use Jetex for the parts:
http://www.jetex.co.uk/website/jetexcus ... tparts.php
Stainless or mild in any normal diameter, just work out what bends you need and how much straight. Each component comes with a socket at one end so they just push together. I normally slot them together and weld most of the joints, using clamps where I need to to make fitting/removal more practical.
Postby Jabba » Wed Feb 11, 2015 12:17 pm
Thanks for the replies. I'll have to work out what length/bends I need and check out some prices.
geoff
Full Name: Geoff Ball
Postby geoff » Fri Feb 13, 2015 9:00 pm
Its Tony Banks in Wortley, he will do a good job
Postby Jabba » Sat Feb 14, 2015 5:42 pm
Thanks Geoff
Postby Matthews » Wed Feb 18, 2015 3:39 pm
geoff wrote:Its Tony Banks in Wortley, he will do a good job
That's the one
Copyright © 2017 Yorkshire Off Road Club
