Postby bandiflip » Thu Aug 19, 2010 6:45 pm
EVEN BETTER !!!!!!!!!!!!!!!!!!!!!! :lol: :lol: :lol: :lol:
Full Name: James Poulton
Postby jim » Thu Aug 19, 2010 7:01 pm
Thats what you call a bobtail 8) Great trials motor and still longer than a zook jimney :lol:
Jim Poulton :)
Postby Matthews » Thu Aug 19, 2010 7:53 pm
I don't wish to be a spoilsport and stop all this fun but I'm pretty sure the MSA have a minimum wheelbase rule and something about engine/transmission/drivers seat being in front of the centreline of the wheelbase and you'll get some pretty interesting propshaft axles, go-on Roger we'll put a special SR in if you do it .
Postby TwoSheds » Thu Aug 19, 2010 9:36 pm
I think that the transfer box would be behind the rear axle on that thing... :D
Postby tecnick » Fri Aug 20, 2010 4:30 pm
Not much space for it in the boot either.
Postby Rod » Fri Aug 20, 2010 10:13 pm
Mathew would all those boring rules count if he competed in reverse.
why is it we cant get new members
Stercus fit !
Postby bandiflip » Fri Aug 20, 2010 10:28 pm
:lol: :lol: :lol:
Postby davew » Fri Aug 20, 2010 10:57 pm
The rule about the axle centreline doesn't apply to cross country, they put an exception in so forward controls could compete I believe.
I think you're main problem will be having to use a lawnmower engine as it's the only thing that will fit. Whilst it will be quite economical you'll have to set off on Thursday to get to a trial on Sunday :)
Postby TwoSheds » Sat Aug 21, 2010 3:51 am
davew wrote:... think you're main problem will be having to use a lawnmower engine as it's the only thing that will fit...
[cunning plan]
but not ...
(cue uplighting and dramatic music)
If I put the engine where the passenger seat should be and turn the transmission through 90deg and then chain drive the axles!
Ha Haaa! Never thought of that one did you?
[/cunning plan]
Bo - up for the challenge? ;)
Postby Matthews » Sat Aug 21, 2010 7:03 pm
Been done before, Mr Milner used to run chain drive axles about 10>12 years ago in comp safari's , the other trick regarding turning engines has also been done using a FWD Rover 800 V6 turned though 90 deg and mid mounted running off to front and rear axle.
Postby TwoSheds » Mon Aug 23, 2010 4:33 pm
Matthews wrote:Been done before, Mr Milner used to run chain drive axles about 10>12 years ago in comp safari's , the other trick regarding turning engines has also been done using a FWD Rover 800 V6 turned though 90 deg and mid mounted running off to front and rear axle.
Eye - there's nothing new under the Sun..
Postby TwoSheds » Sat Sep 04, 2010 8:25 pm
Got a few more hours on it today and made some progress (the wood is there to keep the weld-spatter off various precious things like seats, and the LPG tank...):
Postby Matthews » Mon Sep 06, 2010 7:45 pm
Roger , you've only got 2 weeks till the lake district trip !
Postby TwoSheds » Mon Sep 06, 2010 9:05 pm
Matthews wrote:Roger , you've only got 2 weeks till the lake district trip !
Although it looks a mess, it is quite usable even now... I think that it probably will look a little strange, but I'll be there... :)
Postby TwoSheds » Thu Sep 16, 2010 6:39 am
Supporting framework would have been finished but for a 'measure once, cut twice' error, so I now need some more steel to finish off :(
I have still got two holes to be blocked at the sides of the glass (currently covered with cushionfloor and duct-tape), all other holes are blocked adequately for the trip. I would like to emphasize that the current state is temporary so that I can come to the lakes - most of what you see will be replaced with steel or perspex when I get the time...
I went for a drive last night - it's so quiet!
