Need to gauge it!
- Adrian Dawes
- Full Name: Adrian Dawes
Need to gauge it!
I am planning to fit a Raptor Engineering dash pod into my modified 11A (has 200TDI engine) fitting a CD, CB, toggle switches (for future fitment of lights etc), a Carling hazard switch (just because I like them) and have space for three gauges.
The question is, which three gauges will serve me best? I basically do trials and a few green lanes.
I was looking at a volt meter, oil pressure and possible turbo pressure. However I have been advised that it may be better to forget the turbo gauge and go for an oil temperature gauge as well as oil pressure.
Advice would be appreciated before I look to buy next week
Also does anyone know where I could get the white dial gauges from?
I am also looking for the land rover dash clock.
Thank you. Happy New Year
Adrian
Adrian
You never stop learning!
- Adrian Dawes
Gauges
Gents
Thank you for the advice.
Mark, when you installed your Raptor Pod did you encounter any problems, or have you got any advice to make the fitting smoother?
Adrian
Adrian
Adrian
Honestly it's a piece of cake. The cut-out template comes with it and it's dead easy to fix - just two bolts. The hardest andfiddlyest bit is getting the extra wires fed behind the dash and into the pod. In the end I made a hole in the bulkhead to pass the main extra wires through (with a grommet for waterprofing.
Give me a buzz if you've any probs.
- Adrian Dawes
raptor pod
All
Thanks' for your guidance on the gauges.
After reading everyone's advice, I went for volt meter, oil pressure and a clock as suggested.
Mark, as you said the Raptor Pod was a piece of cake to fit, very simple and straight forward.
Just sorting out the wiring etc
Adrian
Adrian
Users browsing this forum: Bing [Bot] and 33 guests
