DEC the 100" Hybrid
TrickyS2010
Full Name: Richard Spencer
Contact:
DEC the 100" Hybrid
Postby TrickyS2010 » Wed Jan 10, 2007 7:38 pm
This is the 100" Hybrid "DEC" I built ( with a lot of help from father )
It was originally:-
Clicking on the link below will take you to the build gallery :D
http://www.doric4x4.co.uk/mymotors/decsbuild/progal.htm
Postby nicks90 » Wed Jan 10, 2007 9:13 pm
oooooh, very pretty :P
Postby tecnick » Thu Jan 11, 2007 10:19 am
When you build the next one, will it be called Ant to make up the pair :P
TrickyS2010
Contact:
Postby TrickyS2010 » Thu Jan 11, 2007 12:47 pm
It's called Project-Beta :D :-
Postby davew » Thu Jan 11, 2007 2:05 pm
How do you/he go about shortening the roof panel ?
First time I did mine I took it apart at the join in the middle and shortened the back, then riveted it back together again. This looked good apart from the gutters that gave me some grief.
Just did another one, mindful of the gutter problem, I took the back panel out, shortened the top panels and tried to re-fold the top panel over the back... didn't work very well although the gutters are now a lot better.
TrickyS2010
Contact:
Postby TrickyS2010 » Thu Jan 11, 2007 8:43 pm
To shorten the roof :-
Put the roof on the vehicle and make sure the window at the front is in the correct location.
This will give you some idea of where to cut.
Take out the back panel. You need to decide at this point if you wish to make the cut straight on the guttering or at 45 degrees.
Remove the strengtheners from the top of the roof using an angle grinder. These need to be overlapped when it’s put back together.
Shorten the roof by cutting straight round the corners and across the centre section.
Clamp the back panel back to the chopped roof and fold over the middle section. This can then be riveted to give it some strength.
The corners of the gutter can be welded back together.
This leaves the curved corners to be V cut and folded one by one. It usually takes a bit of cutting and filing to get it right. Once they are folded they can be blind riveted back to the roof.
Postby davew » Thu Jan 11, 2007 11:39 pm
Pretty much the way I did it the last time, tried to use a steel jig instead of cutting slots in the curved section of the fold... which is where it all went a bit pear shaped :-) The fold is OK but no amount of persuasion with a shrinking hammer would get rid of the excess. Might bend it back out a bit and slot it like you've done.
I went for a 45 degree cut on the gutters which worked a treat.
Postby Orange rover » Fri Jan 12, 2007 2:41 pm
What a FANTASTIC colour :lol:
martin "orange rover" ellis
TrickyS2010
Contact:
Postby TrickyS2010 » Fri Jan 12, 2007 6:11 pm
In terms of photography its one of the better colours 8)
Postby davew » Fri Jan 12, 2007 6:14 pm
pfff waaaaaayyyyy too common a colour !
pamw
Official
Full Name: Pam White
Postby pamw » Fri Jan 12, 2007 11:52 pm
Nice to see a pic of TYG - even if it is with the rather 'common' orange paint job :wink:
What happened to TYG ? still got ? sold? scrapped ?
Archaeology - my career in ruins !
TrickyS2010
Contact:
Postby TrickyS2010 » Sat Jan 13, 2007 12:00 am
TYG got swapped for :-
Which has been modified :-
TrickyS2010
Contact:
Postby TrickyS2010 » Mon Feb 12, 2007 10:38 pm
Another nice Orange photograph taken by Roger :-
Postby Orange rover » Tue Feb 13, 2007 12:56 pm
Nice orange and snow, it could have been worse it could have been yellow snow :lol:
Another crappy day in paradise
WWW.OCUREM.COM
iluvmud
Full Name: Marc douglass
Postby iluvmud » Fri Feb 23, 2007 6:43 pm
:lol: Smart ninety cool colour :lol:
Users browsing this forum: No registered users and 215 guests
