Self locking door
Self locking door
Postby Jabba » Sun Mar 11, 2012 7:06 pm
My drivers door keeps locking itself when I try to open it from the inside.
Unlock door with key.
Open door and get it.
Close door and drive.
Open door using inside latch, the lock button drops part way and the door doesn't open.
Had the liner off and can't see anything binding or wrong. Squirted lots of oil in the mechanism and kept locking/unlocking it to try and free anything up. It hasn't always done this - just started recently.
Any ideas? Is this a knackered lock that needs replacing? Is there any point in taking the lock out and fettling it on a bench?
Postby kingsonlim » Sun Mar 11, 2012 11:24 pm
there is a small spring in the mechanism to keep the latch up on the disco's. Unsure if the defender's lock mechanism is the same.
http://www.ebay.co.uk/itm/Range-Rover-C ... 2ea9b1ccf1
Postby Jabba » Mon Mar 12, 2012 9:49 am
Thanks Kingson. The lock in their picture looks different. I'll check and see if anyone makes one for the defender.
Postby TwoSheds » Tue Mar 13, 2012 2:06 pm
Totally different, but on the Skoda when I picked it up:
Unlock door with remote, put key in ignition (don't turn on)
Close door and walk away to talk to seller.
Come back and find that the doors are all locked... :(
Postby Jabba » Tue Mar 13, 2012 2:13 pm
Our skoda re-locks the doors if you unlock them then don't open anything within 10 seconds (or something like that). But if you open a door it doesn't. Sounds odd on yours....
As for my door, I think I'm going to add a bit of bungy cord to apply slight tension to the button and hold it up. If that doesn't do it, I'll put up with it as long as I can then replace the lock.
madcalc
Full Name: david medd
Postby madcalc » Wed Mar 14, 2012 11:21 pm
replace cheap spring, take hours to do it :roll:
Users browsing this forum: No registered users and 17 guests
