- Full Name: Nick Adams
Postby tecnick » Sun Apr 20, 2014 1:20 pm
Hi all. Got alternator off, can't budge pulley wheel, any clues?
Need water pump off, can't budge pulley wheel also not sure of size of wp bolts, 10mm too floppy. Any clues.
Rad out for good access and replacent.
Graeme C.
- Full Name: Graeme Christie
Postby Graeme C. » Sun Apr 20, 2014 3:47 pm
The water pump bolts might be 3/8". Do you mean the pulley on the alternator because they can be a b@%$£r to shift.
Postby tecnick » Sun Apr 20, 2014 8:04 pm
Yes, and it is. Had 30ft bars on the swine;)
Postby Matthews » Tue Apr 22, 2014 7:38 pm
Alternator pulley is usually a windy gun affair , water pump pulley bolts are 10 mm but you need a good quality 6pt socket/spanner or you'll round em off
Postby tecnick » Wed Apr 23, 2014 8:09 am
Got it off with angle grinder:)
Postby tecnick » Fri Apr 25, 2014 2:48 pm
now I have found the P gasket, if original is fine, should I just leave it alone or replace it whilst water pump etc is off?
Postby Matthews » Fri Apr 25, 2014 4:41 pm
Replace it
Postby tecnick » Sat Apr 26, 2014 8:49 am
Ok but if I have to marshal my first event this year I'm blaming you. (Going piglet btw, will tell you why sometime)
Users browsing this forum: No registered users and 36 guests
