Jeep amongst the Landy pack )
Postby Zedman » Thu May 13, 2010 10:54 pm
Also done a few minor mods
1. Made a new front bumper from some scrap, i now have front shackle points, total cost 8p, (i needed some spacers, 2p's were just the right thickness and i needed 4, I was upset I had no washers the right size)
2. Removed anti roll bar, then did road test round my nearest roundabout, cant feel any difference, oh well.
3. CB radio fitted for green laning, not sure if it works cos not many folks have CB radio near by and I strongly suspect my daughter has traded my walkie talkies with her friends for girly stuff.
4. Fitted soft top and then found out it is far quicker to unbolt the hard top and lift it off than fold down the soft top, soft top now in the skip ( it was a bit knackered )
Postby Bo » Thu May 13, 2010 11:29 pm
Dont forget you will need a roof to trial.
Roof
Postby Zedman » Fri May 14, 2010 8:30 am
Jeep has a roll cage so roof is not needed, its only glass fibre anyway.
Postby nicks90 » Fri May 14, 2010 10:40 am
fraid not... :cry:
you need some form of covering i believe.
Postby Bo » Fri May 14, 2010 11:28 pm
I think this section covers it:
E.1.1. All vehicles must be in one of the following two configurations:-
E.1.1.1. Soft-top vehicles - must have the manufacturer’s windscreen raised, and complete manufacturer’s hood and support structure in place. The rear flap on the tilt may be secured open.
E.1.1.2. Hardtop vehicles must have the whole of the manufacturer's hardtop or truck cab with all fastenings secured and all glass in position.
Bigger problem is the hole in the radiator
Postby Zedman » Sat May 15, 2010 8:12 am
The bigger problem is the hole in the radiator, anyone know if there is a repair service in the Knaresborough area for aluminium radiators ?
jim
Full Name: James Poulton
Postby jim » Sat May 15, 2010 8:30 am
There is an advert on ebay that do jeep radiators and are located south yorkshire:
http://cgi.ebay.co.uk/JEEP-CHEROKEE-4-0 ... 439f22a08e :wink:
Postby davew » Sat May 15, 2010 9:14 am
There's a place near Thirsk that may be able to help - they built my custom Ali radiator.
Can't remember the name of the place but give Patrick a ring at Maddison 4x4 and ask him about it.
Finaly got it off
Postby Zedman » Sat May 15, 2010 11:08 am
Finaly got it off, one of the cores had a crack in it, the good news is its not ali as I thought its brass, so lots of solder later it looks like its fixed, off for a short test run to get it up to temp, if alls good I am heading over to RHB )
Users browsing this forum: No registered users and 68 guests
